WMH1163XVS1 Whirlpool Microwave not heating food
chrome
El Paso, TX
WMH1163XVS1
Over the range microwave is not heating up the food. No loud sounds, light turn on, plate turns, vent works, new filters installed 2 months ago.
Model: WMH1163XVS1
OK, it's working but not heating. Check for 120 VAC on the primary side of the high voltage transformer. If there's no voltage check the magtube TCO and Cavity TCO for continuity. Check the door switches for continuity by opening and closing the door.
Thanks Rick for helping chrome!
Is this the magtube TCO for his model:
W10598693 Thrmst-Fix
I'm posting the link to a couple videos in case you need them for testing and access to the magtube TCO.
Testing:
Magtube TCO access:
