WMH31017AB Whirlpool over the range microwave stopped working
RjRaye82
Pittsburgh
WMH31017AB
Hello all! My microwave started acting really weird recently and then it just stopped working all together. When we tried using it the unit would simply click then stop and turn off. I figured out it was the door switch and replaced that. Now it will heat but will not illuminate the light and the turntable will not work. If I hit the side of the microwave it will come on and work for a random amount of time then go right back off. I can hear a relay clicking inside but can’t determine which one it is. Please point me in the right direction.
Sounds like a bad connection on the board. Here's the part you need:
RjRaye82
Pittsburgh
Holy crap, $311! I’ll just replace the microwave for that much. I was hoping it wouldn’t be the board. I think I’ll just deal with no light for now. Lol. Thanks for the reply.
You can look for something obvious on the board. Cold solder joints is common. Use the eraser side of a pencil to touch the board components. Maybe you'll find it.
