FIXED WMH31017AW Probably the door switch sensor
applegate123
ithaca, ny
WMH31017AW
Hello,
I have seen a couple other similar posts - but wanted to confirm.
For the last several months, when I open the microwave - the light in the microwave would click on and off several times - on-off-on-off-on. 2, 3, sometimes 6 times. Sometimes when it gets done clicking - the night might be on or or it may be off. Today for the first time - I opened the microwave and the light did not come on, I set the timer, pressed start, then a "door" message was displayed [when the door was alreadt closed]. I opened and close the door a couple time hard - and then I was able to operate the microwave.
Could you provide a part number and general instructions for repair?
Mark
applegate123
ithaca, ny
Actually, Model Number is WMH31017AW3. Based on some other messages that I have seen - I am going to guess that the switch to replace is the one with 3 connectors - W10727360. I will try this and see what happens.
applegate123
ithaca, ny
Microwave has been fixed! :)
On a related note: when I removed the control panel - there are 2 plastic (??) tabs on both sides of the control panel (4 in total). However,the panel is held in place via 4 metal tabs next to the plastic ones. 3 of the 4 tabs had previously broken off (laying inside microwave) and the remaining one was cracked and I took that one off. The panel has some wobble in it without these plastic tabs. Is this a common issue with the microwave? The microwave is only a little over 1.5 years old. Don't know if this is a design flaw or if somehow it might have been this way since it was installed.
applegate123
ithaca, ny
Yes, #2. there are plastic tabs - two on the right and two on the left - you can see them in the parts diagram on the right side (little bumps). I might just get a new panel.
Thanks as always!
Yes, I do see the little bumps now that you pointed that out to me.:)
Yes, a new control panel would fix it.:)
