WMH32519CS Microwave Intermittently Doesn't Work
Lassen
CA
WMH32519CS
With increased frequency, the microwave won't turn on. The display and clock still show but then the light in the microwave won't turn on and the microwave won't either. Opening and closing the door seems to help. Once the light turns on the microwave will work. Any help is appreciated!
WMH32519CS1
That one works :)
I checked out a very simular one the other day and all the door switches and door mechanisms checked ok. Ended up the pc board could no longer "see" or "tell" the door was closed.
If needed
Door-Switch-W10727360-01811635.jpg Door switch, three terminal
