WMH53520CS0 Microwave Intermittently Doesn't Work
K Flowers
Tuscaloosa, Al
WMH53520CS0
Having a similar problem with WMH53520CS0. Intermittent open/close door message (becoming more frequent). Checked all 3 door switches yesterday, all appear to be working ok. No other obvious problem. What should I try next?
Thanks KF
Jeff is taking time off, so I will need to move your post to your own thread.
Rick is very good with Microwave's.
Look here at this thread, its a similar problem to yours:
