FIXED WMH73521CS5 Whirlpool Microwave no power
Roger62
Arkansas
WMH73521CS5
I have a Whirlpool Microwave model WMH73521CS5. I was having the issue with it not thinking the door was closing and I stuck a knife in the latches to close the circuit, when I opened them back, it popped and lost power. I have checked the fuse with a DMM and it appears to be good. I have power to the outlet. Does anyone know what I need to look at next?
Can you verify no display, no lights in cooking cavity when door open, no vent fan etc.
You checked the white cylinder fuse On the filter board as shown?
I found the second fuse earlier today and this fixed it. The first fuse was right behind the main board. I had checked it but didn’t see the second fuse until I took the whole cover off.
