WMH73L20AS Whirlpool Microwave not coming on. Door switched are good.
Wayne Pace
WMH73L20AS
My Whirlpool over the oven microwave stopped working. Everything appears to work correctly. Panel, display, lights...
When trying to start microwave, there is a audible relay click like usual, but then nothing happens. No timer countdown, no inner light. Everything just stops.
I have confirmed the door switches and overheat thermostat are good.
Suspect problem is with the board. Does anyone know anything I can check on the board? Is the board schematic available online?
If the cyclotron is bad, what does the microwave do? Trying to figure out if there is any info out there to troubleshoot the control board or tell which function or safety feature is keeping the microwave from starting.
Thanks for any info!
