WMH76719CZ1 Whirlpool Microwave - Open close door
Uthguy
Abilene, TX
WMH76719CZ1
I have a Whirlpool microwave/convection oven (WMH76719CZ1) which stops working intermittently. It will give the open-close door message and not work. I can sometimes swing the door back and forth to get it to work but sometimes not. I know it is working again when the light inside the oven comes on. I removed the upper panel and there are wires on the left side going into the door. I can jiggle these wires sometimes and get it to work so I think the problem is somewhere inside the door itself but I cannot find anything on how to get inside the door.
The inside choke, #3, unsnaps. Use a small screwdriver or a putty knife and start in a corner then work your way around.
To remove the door, remove the plastic insert below the upper door hinge:
Disconnect the wire harness. Lift up and pull out:
