WOC54EC0AS00 Whirlpool microwave and oven combo - error code F1E5
wirlpool_fix
MD
WOC54EC0AS00
Mine is a combo of microwave and oven.
Microwave has the following error codes F1E5 and F6E0. But the funny thing is that it says that no faulty error detected.
Currently a technician attempted to fix the problem multiple times - replaced an appliance manager, a control board, an inverter, and a magnetron , but still the microwave doesn't work. He said this would be a very unusual case. Only option left is to check the wire and a bracket, which will cost a thousand dollars and even no guarantee to fix the problem.
Is there anyone that has the same issue and any luck to fix the problem?
Any advice would be appreciated.
OK that doesn't sound right. After the new part is installed you need to go back into service mode and clear the error codes. Wire? Bracket? Thousands of dollars? He's obviously missing something.
