WOC75EC7HS00 Whirlpool Microwave Oven Combo Open Door issue
blues45
Toronto
WOC75EC7HS00
Hi, new here.
I have this combo, manufactured in 2018. WOC75EC7HS00 Whirlpool Microwave Oven Combo
The microwave door seems to have an issue. If I press the door in hard, the microwave will start for a few seconds and than disconnect. If I close the door normally, microwave thinks the door is open.
There is no error code, it just thinks the door is open.
Any suggestions? Thank you.
This is the update kit you need. Installation can be a little tricky
blues45
Toronto
I'm not sure if I have the technical skills to install this... the best I can do is install a light fixture.
Might need to look for a technician, but afraid of being scammed by them.
