Wolf microwave MWD30-2F/S
Oliver1974
Los Angeles
MWD30-2F/S
Привет! Есть проблема.., не знаю как исправить... Микроволновка Wolf MWD30-2F/S. Дверь автоматически входит выходит. Проблема: дверь заедает на полпути. Нажимаю кнопку "закрыть" - немного шевелится и опять подклинивает. Где искать в первую очередь? Переключатели заражены - все в порядке.
Я думаю, что плата управления сломана, но я сомневаюсь... у вас есть опыт?
Translation from Russian to English, but still didn't make much sense to me.
Hello! There is a problem.., I don't know how to fix it... Microwave Wolf MWD30-2F/S. The door automatically enters. Problem: The door jams halfway through. I press the "close" button - it moves a little and wedges again. Where to look first? The switches are infected - everything is fine.
I think the control board is broken, but I doubt it... do you have experience?
I hope someone can help.
jeff sr.
Hi Oliver,
Please only use English here when posting. You can use google translate and then copy and paste the conversion to English here.
Oliver1974
Los Angeles
The door is half open. I can’t figure out which spare part to replace ... If you turn off the power, the door can be closed and opened by hand without problems.
