DI-WHY Guy72
- WPRE6150K2WT
- GE
- 6-10 years
Hello my name is Eric,
My washer won’t agitate or spin, It will fill and drain and the timer seems to be working fine.
I took the front panel off, tested the magnetic lid switch and it seems to be functioning properly. The LED light is showing a 6 flash error code. I did the motor reset opening the door and closing 6X it 12 sec. That did reset the motor Error code to normal function but returns to 6 flashes when I run a cycle. I’m thinking the motor is bad but want to see if there is anything else I can test before going with replacement.
Any help would be greatly appreciated!
