WRB322DMBM00 No interior lights or display on Electronic Dual Control
GregSS
OK
WRB322DMBM0
We recently acquired this refrigerator and there is no display on the Electronic Dual Control or interior lights. Freezer has lights when door is opened.
Refrigerator is cooling. I have replaced the Jazz board but have the same results but without cooling.
Any Ideas?
Thank You in advance
The problem is most likely the door switch failed. Use a DMM to check it for continuity.
The new Jazz board won't work until you program it with the code on the model/serial number tag.
Here's the part you need:
WPC3680310 Light Switch
