WRF535SMBM00 Whirlpool Refrigerator - Ice Maker not Making Ice
g592713
Albuquerque, NM
WRF535SMBM00
Ice maker on fridge not working. Checked the water line and didn’t see any issues with water flow.
Everything else is working with the fridge and freezer.
Would appreciate any advice on other things to check to try and locate the problem.
Remove the front ice maker plastic cover, it just unsnaps off. Put your multimeter PROBES in L and N on the ice maker module you should get 120 volts.
Now on some models you have to push and hold the door switch in while testing for 120 volts and while forcing a cycle by jumping T and H.
You can force a cycle. You will see test holes with a Letter next to each hole.
(click to enlarge)
Short T & H with an insulated piece of wire ( 14 gauge) with the ends of the wire bare approx 1/2" to run the motor, The wire needs to be about 3" long and the ends stripped to make contact in the holes.
Make sure to take the jumper wire out at about a 1/4 to 1/2 a revolution.
You can just make a jumper wire if you have some old wire laying around in your garage or house, then just cut some off, and take off the insulation on both ends about a half inch.
I use a wire stripping tool: Wire Stripper
If you get 120 volts and when you jump T and H the ice maker does NOT start to cycle, then your ice maker is bad.
Here's the ice maker for your model you can order:
W10884390 Icemaker
g592713
Albuquerque, NM
I’ve ordered the ice maker and will be replacing it.
Would appreciate any tips you have on removing and installing the new part if there are any.
Thanks.
You first will need to remove the freezer door, I'm attaching the instructions to do that below.
On page 7 read where it says Freezer Drawer Models.
On page 10 is the photo's that show you and to remove and replace the freezer door.
Then all you do it loosen the top two screws that hold the ice maker in place, some also have one screw on the bottom of the ice maker, that one you remove completely. Then lift the ice maker up from the top two screws you loosened then remove the electrical connector to the ice maker, it just unsnaps off.
  • WRF535SMBM00.pdf
nvtroutman
Nevada
Hi Jake,
Do you happen to know what the letters indicate on the front of this unit? I've been trying to find a spec on the part but I'm coming up short. I assume that N is for neutral but I'm unclear on the rest.
Thanks for your help.
Yes, look here:
nvtroutman
Nevada
Great! I assume that the letters mean the same no matter the orientation on the module? ex. in the original image the N is located in the lower right, next to the H, conversely, the N is located at the top of the image in which you provided.
Thanks again!
Orientation matters not.:)
