WRF736SDAM11 Whirlpool Gold Not Making Ice
KMMOM
Kings Mountain, NC
WRF736SDAM11
I have a Whirlpool Gold that is not making ice. I have run diagnostic test and it says the ice maker is working. However, under Service Test - 58 Ice Maker Heater Activation and Thermistor it codes 10 (warmer than harvest temp) I’m not sure what this points to, if anything at all or where to go from this point? I looked at a thread that suggested the problem could be the filter?
I'm attaching the tech data sheet for your model below. Do TEST 56 and TEST 57 and let us know what you get.
WPW10764668 Ice Maker Assy-Lp
KMMOM
Kings Mountain, NC
The water filter switch status after testing is saying the switch is closed (water filter not installed) However, a brand new filter is in it. Could this be the problem?
Ok, is the part number on it from Lowes EDR2RXD1?
Have you replaced it before for the Lowes one?
If so, and it worked fine, then take it back to Lowes, its possibly defective.
KMMOM
Kings Mountain, NC
If so, and it worked fine, then take it back to Lowes, its defective.
I checked this yesterday it is the correct filter. Also, thinking maybe this was the problem, I bought a new filter and installed it yesterday. Still no ice production and the code that says no filter installed is still the same?
Ashley
Ok Ashley, this is a newer model that has something called a "smart filter switch" I can see it on your tech data sheet but I can't locate it in your parts diagram, so I will need to ask Rick if he knows where to find it.
Do Service Test - 67 Water Filter Switch Status
That switch may be bad.
That's what I don't know, I messaged Rick to see if he knows.
Rick should be here shortly.
Wait I just found it, its on page 5-7 of your service manual here: https://drive.google.com/open?id=1RC_TwqEUEt3auvQDQeeaxHkKZ3XZ7mmc
Its quite a job to get to it, but it shows you the steps.
Wait, it gets even better, I found a video on how to access it, click the part link to it below, they call it a door switch, but its your filter switch:
KMMOM
Kings Mountain, NC
Awesome! I’ll get the part ordered. It didn’t look too difficult. I hope this will fix the problem 🤞🏻I will let you know what happens. Thanks for helping me work this out!
Ashley
Glad to help Ashley, I learned something new too.:)
Yes, let us know how it goes.
Sorry, got here too late. Went fishing and stayed the night at Strawberry . Looks like you found it. It's a door switch.
Its ok Rick, I had a feeling you went out of town again, Hope you had a good time.:)
KMMOM
Kings Mountain, NC
Update: Installed the new switch still no change in the status. Service Test 67 still test 02, switch closed filter not installed.
Under Service test 58 I’m getting temps warmer than harvest temps. Could that be my issue?
Make sure the black wire is on the COM switch terminal and the light blue/black wire is on the NC switch terminal. Temp warmer than harvest temp is normal if the ice maker went through a harvest cycle or if test 56 or 57 was run. Unplug the machine and check for continuity between the small terminal on the power cord and P2-4 on the main board.
KMMOM
Kings Mountain, NC
The COM wiring looks correct. My problem with the ice maker started after a power out in a thunderstorm we had here. I’m not sure about your last instruction I will need to find some instructions on how to do that. Just a single mom trying to avoid a repair call if I can manage it.
