FIXED WRF736SDAM13 defrost problem - iced up
G
Guest
Guest
WRF736SDAM13
Hi jake ,
I went through your conversation above. I have same model whirlpool WRF736SDAM13. I have same problem which occurred second time in 11 month later. Last time in jan 2019 , Defrost thermostat faulty so i just replaced it with different spec like open and closing temp, it keep working from last 11 month, few days back same problem occurred again , there is frost all over coil. today i tested defrost thermostat and heater which are good , thermostat open close by changing temp and heater is heating by connecting directly to AC.
Do you ship component to Canada?
You just follow everything I mentioned above, since yours is the exact same model.:)
Yes, you can order the new control board, It does ship to Canada too.:)
WPW10589838 Electronic Control Board
Plus you get $60 credit on your credit card when you return the old one.
Ok, let us know how it goes after you replace the control board.
Excellent, glad to hear that. (y)
