WRF736SDAM13 Whirlpool fridge not cooling below 45 F
Nateberg
Ky
WRF736SDAM13
Service test says the evaporator fan is on and the air baffle is closed.
sound like a bad motor?
DO--->Service Test - 2 RC thermistor
• The board will check the resistance value of the thermistor and display the results on the Temp
Display (01 = Pass, 02 = Open, 03 = Short)
Service Test - 3 Evaporator fan motor and air baffle motor
• Turn on the FC Evaporator Fan and Air Baffle and monitor the Air Baffle feedback. SW3 (01= Fan On / Air Baffle Open. 02 =Fan ON / Air Baffle Closed.)
Your air baffle should be open not closed. So that sounds like the problem.
Here's the air baffle for your model:
WPW10479155 Control
Nateberg
Ky
I ran service test 3 and when it was flashing 01 no air was coming out the back.
when it was flashing 02 air was flowing, is there a delay maybe?
thermistors check out as well. Any thoughts? SW3 will not let me select 01 or 02 functions. It switches back and forth after approx 10 seconds.
Is the evaporator fan motor running?
Nateberg
Ky
Yes, evaporator fan comes on, compressor and condenser fan come on as well. I’ve got it all apart and can see them running. Not a significant amount of air flow into the fresh food compartment, plenty of cooling in the freezer.
You need to have the evaporator cover in place so more cold air gets into the refrigerator section.:)
