WRF736SDAM13 whirlpool gold French door fridge constantly resetting.
Nate B
WISCONSIN
WRF736SDAM13
WRF736SDAM13 whirlpool gold series fridge.
About a day before reset and control panel issues door was left open a little long, about 20 minutes. In the past we had an issue in a similar situation where it seemed to cause some condenser issues and eventually a control panel that kept resetting. We had it powered down for several days and it seemed to fix the issue. No luck this time. When I power the fridge up it powered up then down every about 5 seconds. If I open the freezer door it doesn't until the condenser starts running about 10 seconds, when it then resets. After the reset the condenser doesn't start again. Am I out of luck, or is there a more nuanced way to reset before I start digging into the control board?
Nate B
WISCONSIN
Thanks. Sorry for jumbling terminology. In your experience this is a control board issue?
Yes, if you want to check the voltages at the power supply board here's the pinouts. If the power supply voltages are correct, bad control board
