WRF736SDAM13 Whirlpool Refrigerator - icemaker quit making ice
cattleman77
SW Indiana
WRF736SDAM13
My icemaker quit making ice. I replaced the icemaker. Still would not make ice. I found this website and checked dcv on ice level emitter and receiver. I get 14vdc on J1-1 to J1-3 and J1-3 to J1-4 on the receiver. I get nothing on emitter j1-1 to J1-3. I replaced the emitter and still get nothing. I even checked for voltage on the receiver J1-4 to J1-6 and got nothing. Could my controller (W10864261) be bad?
The numbers do not completely light up when I am doing any sequence test and the sequence tests start at 11 not 01 as I think it should. Or could it be the main control board. Or could it be something else or possibly it is just me. Thanks for any help
Cattleman77
Try J1-4 to J1-6. Sounds like a bad receiver board.
cattleman77
SW Indiana
I forgot to mention that I have also changed the receiver. Both of the receivers could be bad though.
Thanks, Cattleman77
cattleman77
SW Indiana
voltage across J1-4 and J1-6 is zero vdc. J1-1 to J1-3 and J1-3 to J1-4 is actually 13.74 vdc not 14vdc
Thanks, cattleman77
cattleman77
SW Indiana
I downloaded 106.51133210 from this site and it shows j1-3 to J1-4 at 14vdc. I do get 13.74 vdc across those 2 connections. I guess I must have used the wrong picture. I will make a copy of the one you posted.
Thanks, Cattleman77
Your model is not a Kenmore 106.51133210
Go by Ricks diagram in post #2.:)
I'm also attaching your tech. data sheet below.
  • W10568023 .pdf
