Reserector
- WRF767SDEM01
- Whirlpool
- 1-5 years
Refrigerator was not cooling enough, but freezer worked fine.
The upper section's evaporator had iced up.
I removed the interior and ice maker for access. I thawed the evaporator with a heat gun.
Fan was working. All seemed fine, but upper section only gets down to 50 F.
By the next day, the freezer began to thaw. FC fan not working. Led lights work normally with the switch.
Evaporator in freezer was iced at top right where it connects to the system, but the evaporator itself is not cooling at all. I thawed the ice with a heat gun.
I have replaced the fan and sensor assembly up top along with the air control to the left of the fan. New,genuine parts. No improvement.
I ordered the freezer fan and sensor assembly, but it is on backorder. So I ordered just the thermistor and defrost switch separately. I compared resistance of the replacement parts to the existing parts and they have the same readings, so I did not replace those.
Defrost heater has continuity.
I've been searching online for my symptoms with no luck. What can I check next?
