- WRF990SLAM02
- Whirlpool
- 1-5 years
So, my ice maker isn't making ice. It passes all the Service tests, except for Test 15 - Ice Level Sensor - which shows 01 Bin Full when the bin is empty. When manually filled with water (Test 45), it quickly freeze it into ice, and will successfully run a Harvest via the Service test (Test 57).
Measuring voltage of the sensor receiver board between J1 and J3 I get 30 Volts...and between J4 and J6 I get 0 Volts.
Looking at an earlier post shown below, it looks like I should have 14 Volts between both those points. I also verified I have 0 Volts at the Sensor Emitter J1 to J3.
The diagram shows the incoming 14 volts between the receivers J1 and J3 is coming from the "Dispenser Board". So my best guess is that is the offending component here.
Can anyone tell me what/where the Dispenser Board is?
a
