WRS315SNHM01 Whirlpool side-by-side freezer won't stay cold
Stealth57
SFO
WRS315SNHM01
Less than 1 year
Whirlpool told me that using the mid settings for both the refrigerator and the freezer would give me 0 degrees in the freezer and 37 in the refrigerator (those are recommended temps for food safety). I noticed that ice cream was very soft, so I decreased the temperature control to mid/max (one less than full cold) and pushed the freezer slider to coldest. I then connected a temperature logger to the mid points of both compartments and found (see attached) that the refrigerator was very stable around 33 degrees, but that is dangerously close to freezing liquids, and the freezer was very unstable. The freezer ranges from -5 degrees when the compressor is running and 10 degrees when it stops. In a 2.5 hour cycle, the freezer is only near zero for about 30 minutes. I need to increase the refrigerator temp but lower the freezer temp. Those requirements conflict with the controls.
Can anyone suggest if the attached chart indicates a leak or other issue? I have a service tech coming out in 2 days under warranty, but want to make sure I have a good idea what's up before he gets here.
The X-axis is minutes and the Y-axis is degrees F.
