WRS555SIHZ06 Whirlpool fridge door doesn't seal
_user_name_
us
WRS555SIHZ06
Less than 1 year
i have a brand new side-by-side fridge (just delivered) and the fridge door doesn't seal on the top left corner (and about half way down the left side). Lowes won't send anyone out until tomorrow and I have coolers of food that need to be put away.
Anyone know some quick checks or adjustments that i can do to fix this? I've taken out all of the shelving, the gasket looks clean and clear of any obstruction. I can press on the door to close it, but it pops right back out.
screenshots included
Were the doors removed for delivery or installation?
If not, you can make sure none of the gasket has pulled out of the door mounting slightly. You can also soak a cloth in as hot of water as you can stand and knead the gasket to soften gasket material, especially toward the hinge side. Those gaskets will compress slightly over time. If a portion is just misshapen from shipping it will often settle quickly.
I don't see any reason you can't stock the fridge. I really doubt they'll replace it for just that and any fix is unlikely to require it being emptied. Maybe don't buy any more groceries until you know what's the cause.
JMO
_user_name_
us
Hey Dan
Thanks for the reply. The doors were not removed as far as I know, and the gasket seems to be in place all the way around. I'll give the hot water a try and see if that helps
I didn't want to stock the fridge just yet because it doesn't seem to be getting colder than ~50 degrees. still periodically checking though
edit:
it is down to about 42 now. so i'll keep waiting.
Yes, once it cools down.
Running it with the small gap at the gasket shouldn't affect it much.
How did you make out with this? Others might be interested in knowing.
_user_name_
us
Hey Dan,
Lowes stood me up and never came out (frustrating experience, to say the least)
The gasket eventually expanded (after about 4-5 days) and it seems like the door is sealing, and the temp seems to be holding well. The fridge door still sticks out a little further than the freezer, but it doesn't appear to affect the functionality.
Thanks for the followup. The door might settle in further with time.
You might want to let Whirlpool and the dealer know so they have a record though. Usually cosmetic things are only covered by warranty for 30-90 days. They might offer a couple of bucks settlement in place of inspecting it if it doesn't bother you too much?
