FIXED WRS571CIDM01 Whirlpool Refrigerator - Ice dispenser not working
Redwing1
RI
WRS571CIDM01
French door Whirlpool making ice but not dispensing. When the paddle is pushed the light lights, the dispenser door opens but the auger does not engage. Checked the motor and it has continuity. Help?
Hi, Let's first check for broken wires to the auger motor. This model is very notorious for broken/frayed wires, where the wire harness goes into the bottom of the freezer door, that will cause no/low power problems to the auger motor.
(click to enlarge)
--->Lots of members have found frayed and broken wires causing the auger motor or ice maker to be dead. Remove your bottom kickplate grille, Remove the black wire harness loom too, broken wires can be underneath it.
Another member was having a similar problem here: FIXED: GSF26C4EXY02 Whirlpool Gold Ice Maker Problem Look at his post #6 he found frayed and broken wires underneath the freezer door.
Here's another one with the same thing about the frayed and broken wires: FIXED: 106.51173310 Kenmore elite ice maker not working - no led light
Here's another: FIXED: Whirlpool WSF26C2EXF01 Door Icemaker Not Working
Redwing1
RI
Yup the same blue wire is partially broken. See pic. What kind of connector would you recommend?
Redwing1
RI
I wound up using a couple of butt splicers adding in an extra couple of inches of wire. Worked perfecto and I'm dispensing ice again. Thanks all!!
Excellent, that's exactly what I was going to suggest.(y)
