WRT108FZDW02 Whirlpool Refrigerator - Food in refrigerator freezing
Brianswensen
California
WRT108FZDW02
Food in the refrigerator will freeze every few days. It also seems to be over freezing things in the freezer. I changed out the control board (W11353813) thinking that is the only thing controlling both the freezer and refrigerator sections. This didn't seem to work. I am going to put in both temperature sensors next, but is there anything else I should be looking at? The diffuser (W10861170) seems to just be an opening without a damper door, so I figure that is likely not the problem. Thanks for your help!
Hi Brian,
I located a service bulletin on this problem, what is your serial number?
It applies to Serial Numbers: VS501 – VS611
If your serial number DOES NOT apply, Then it has to be the refrigerator section thermistor.
Here's the refrigerator section thermistor for your model:
W10838965
