tendrew7
- WRV976FDEM01
- Whirlpool
- More than 10 years
Refrigerator is a Whirlpool WRV976FDEM01 5-door French style
I have a very similar issues to one already discussed in a previous thread:
www.applianceblog.com
The ice maker tub ran empty with no more ice being made. I don't believe there is any water in the ice trays. I examined the wires traveling through the hinge and didn't find any fraying. Then randomly a couple hours later we hear one batch of ice dump, but there hasn't been any more made in the last 24 hours.
During the testing I had:
1. Refrigerator on
2. Ice maker turned on
3. The door switch was taped shut
4. The ice bin flap was taped shut
Testing across J1-1 and J1-3 on the receiver, I measured 12.7v
Testing across J5-1 and J5-3 on the emitter, I measured no voltage
No blinking from the red LED either
These results were consistent with the previous thread. Here is where I am stuck.
The tech stated the problem was the receiver, but the "customer" stated the appliance repairman only had to replace the emitter, not receiver.
Also, I used my cell phone camera and found the infrared emitter was strobing which tells me the emitter is working.
So, is either/both the receiver or emitter bad?
Should the infrared be a steady on instead of strobing?
Thank you for any help.
FIXED - WRF736SDAM13 Refrigerator Ice Level Sensors
My refrigerator has stopped making ice. Other than replacement, is there a way to check the Ice Level Sensors to prove if they are working or not? These parts are not inexpensive so I don't want to replace parts that are not needed. I have run the diagnostics on my refrigerator and everything...
1. Refrigerator on
