WRV986FDEM01 Whirlpool double drawer dual ice makers quit at same time
Jamie H
Kansas city
WRV986FDEM01
We have a whirlpool gold series double drawer refrigerator with a bottom draw second ice maker. Both ice makers stopped working at the same time. I have replaced water inlet valve, water filter and both ice makers. I can manually cycle it and got both of them to fill but they will not harvest. I have unplugged, reset with the lock/measured fill buttons, service diagnostics says No Errors. What am I missing? The water dispenser does work. We have been battling this for over a week giving it plenty of time to produce but still no ice. Anyone had this issue?
Does your Temperature control Pantry drawer inside the refrigerator section no longer have a display? Is the display out?
There have been a few members that have found that Pantry UI control board shorted out and thus it will cause the ice maker/dispenser to stop working.
There is a service bulletin about this problem: https://drive.google.com/open?id=1OUD3L2YYjwGY48xB2u1jH-LMZXwtUl4a
Disconnect it and see if everything starts working properly again.
Here's the Pantry UI control board for your model: WPW10677119.
Ok, I will ask Rick what he thinks it might be, I've never run into this problem myself.
We did have a member with the same model number as yours with a similar problem and it was he dual water inlet valve that was the problem:
I know you said you replaced the water inlet valve, but was it the dual one in his thread, this one: WPW10341329
Jamie H
Kansas city
The water value is working. We got both ice makers to fill but not harvest. I have confirmed it is a dual water valve. Lightning works, pantry controls work, cooling works. I just can’t help but think it has to be a control board they share I just dont know where to look.
How did you get both ice makers to fill? Did you force cycle them? Do they both have ice in the ice mold? What setting or temperature is the freezer set for?
Jamie H
Kansas city
The bottom one we manually cycled the system and the top one we went through the diagnostics tests and it filled. My ice sensors doesn’t have power but all my door functions work and the dispensers works. I believe the sensor is bad
You missed one of Rick's questions: What setting or temperature is the freezer set for?
That's very important to know because if the temperature in the freezer is not below 16 degrees both ice makers will never cycle the ice out.
Ok, that's fine. Your ice maker sensor only controls your refrigerator ice maker, not the freezer ice maker, that's why this makes no sense to me how both can go south at once.
Jamie H
Kansas city
The bottom ice maker started working this afternoon and I order the ice sensor transmitter for the upper ice maker as the red light on the sensor wasn’t working.
Ok, glad to hear the bottom ice maker started working again.
Here's the ice maker emitter sensor board for your model:
W10870822 Cntrl-Elec
Jamie H
Kansas city
Git appears the bottom ice maker has quit again. Any ideas why it would quit? There is ice in the maker
Nope, you've already replaced the parts that would cause this problem. Unless Rick knows what else you can check, then its best to have Whirlpool come out to see what's going on.
I don't think there's a common problem for both ice makers. Freezer ice maker only:
Check for 120 VAC across holes "L" and "N" on the power module. If the voltage is correct see if you can force cycle the ice maker. Use a small piece of insulated wire bent in the shape of a "U" and short holes "T" and "H" then remove the wire. You may need to hold the door switch closed.
Jamie H
Kansas city
Is this for the bottom ice Maker? I’m still waiting on the receiver to get here for the top ice maker
