rickdilley
- WRV986FDEM01
- Whirlpool
- 1-5 years
I have been troubleshooting problems with this refrigerator. Have had some intermittent lighting problems where when the doors are open the led lighting does not turn on and none of the water/ice makers work but this has cleared itself up within 30 minutes every time (until now). Had some water leakage from the upper ice maker recently and then all of the ice makers and water dispenser stopped working.
I tested and found that the main water inlet valve was bad and replaced. Now that that is replaced the lower ice maker seems to be working ok but if I use the water dispenser the water comes out the lower ice maker right into the storage bin. I have done some voltage tests and when the water dispenser paddle is pushed the pins on the main controller board plug P3 pins 3 and 4 both go high (120vac).
Haven't been able to catch it when the ice maker is filling to check the voltage readings (tried but just haven't made it in time). I am surely looking for some advice. I am leaning towards the controller board but would like some input from a professional before I order one. Also I have unplugged unit and removed all cables from all of the boards on the back side and also the pantry wires on the front drawer and then reinserted them. I also do have the tech sheet for this unit.
