WRX735SDBM00 New whirlpool refrigerator water dispenser not working
TracyM
United States
WRX735SDBM00
I just bought this from a Sears outlet store. The water dispenser is not dispensing water. In researching the manual I found a note about connecting the water line to a reverse osmosis filtration system which we have. It said we need PSI of 40-60 when connecting to reverse osmosis...how do I find out what my water pressure from the system is? I have no idea. And then the manual said that we could disconnect the filter in the fridge, which we did and still no water. I'm doing the 5 seconds on 5 seconds off to get it to go. How long should this continue?
The easiest way to check your pressure is to go down to your local hardware store and get a PSI water pressure tester. Most have a hose fitting and you may have to get a adapter for a 1/4 " pipe. Connect the hose at the back of the refer to the tester and see what your pressure is reading.
When you get a brand new refrigerator you have to keep holding in your water dispenser lever because you have a water tank in your refrigerator section that needs to fill first before you see water coming out of your dispenser.
Glad to help.
Keep us posted.
