Grizzlyman
- WRX735SDBM00
- Whirlpool
- 6-10 years
Our 10 year old Whirlpool model WRX735SDBM00 is slow to produce ice. The ice maker was updated two years ago with the updated wiring harness and maker. It was making ice as it should since the day we purchased it new in 2013 and after the replacement ice maker. Now it only cycles ice a few times per day. A few months ago we started running out of ice so I when through the troubleshooting steps. The frig area temp is 35, the freezer box is -1 and the ice compartment is 18 degrees.
I did lower the freezer temp as low as I could on the display and it will not drop below -1. I know 18 degrees in the ice maker compartment is not cold enough to make ice properly. The condenser coils are very clean, new water filter, no error codes in diagnostic mode 37. The ice maker fan is working as it should. I actually removed it and tested. Service mode 36 turns the fan on as it should. The damper door seems to be working as it should. The evaporator fan in the freezer is running and appears to be strong.
I was told the evaporator fan can become lazy but I have not taken the freezer apart to check the evaporator fan motor as it appears to be strong by feel and hearing it. How can I get the ice maker compartment colder? Any assistance is greatly appreciated.
I did a search before posting this thread and found someone with the exact same issue. Their issue was the ice maker fan but ours is working.
