- WRX986SIHZ02
- Whirlpool
- 1-5 years
Good morning! We have a Whirlpool WRX986SIHZ02 and had it a few months under 2 years. I recently noticed our ice maker would randomly stop making ice. I looked at the ice bin and noticed a hole in the side of it where ice must have gotten wedged and the pressure eventually caused a crack and ice busted through. That led to ice building up under the ice bin and freezing up. I got the ice out from under the bin so I could finally pull the ice bin out. I let it melt and dry out completely. I then put the bin back in and it started making ice again but froze and ice maker stopped. For some reason I thought the ice getting under and freezing up stopped the ice maker from working. I ordered a new ice bin but ice maker isn't working at all. Below are the results of the tests I ran:
Service Test 36 - Ice Box Fan = Returned 1
Service Test 37 - Ice Box Thermistor = Returned 01
Service Test 56 - Ref. Compartment Ice Maker Error Codes = Returned E2 indicating the motor lost position
Service Test 58 - Ice Maker Heater Activation and Thermistor = Returned 00 indicating ice maker heater is off and temp is warmer than harvest temp but not sure this means?
Service Test 59 - Ice Maker Motor = Returned 10 indicating motor was rotating and in progress. After 70 seconds it returned 02 indicating motor off and harvesting not complete (timeout I guess)
Any thoughts on other tests I should run or thoughts on what the problem is? Just from the tests I ran, assuming the motor died. Thanks in advance for any help anyone can provide!
