WRX988SIBH00 Whirlpool Refrigerator Icemaker,no ice.
pipewrench713
Glendale ,CA.
WRX988SIBH00
Model WRX988SIBH00.....
I changed the ice maker and the dual solenoid ,inside in panel, located on top . The cup filler is getting water, so water is getting unto that dual solenoid.
But the ice maker not getting water? Any advice. THANK YOU !!!
bigbuck
From Planet Mars
Here is your tech sheet.
  • WRX988SIBH00 Tech Sheet - W10503798 - Rev C.pdf
Thanks bigbuck!
Hi pipewrench,
Let's check for a error code. Do Service Test 56
Service Test - 56 Ice Maker Error Codes
• Displays active Ice Maker Error Codes on the UI display. (E0 = No Errors, E1 = No Cooling, E2 = Motor
Lost Position, E3 = Heater Timeout, E4 = Dry Cycle, E5 = Timed Ice Making)
