WRX988SIBM00 Ice maker not working - emitter issue?
Bob182
Chicago
WRX988SIBM00
Like many have experienced, our ice maker stopped working. Here are my steps to try an troubleshoot:
  1. Ran the diagnostics (service test #56) and got an E2 Motor Lost position
  2. Ran # 57 and it states that the Harvesting Not complete
    1. I noticed that the heater turned on and the the tray was warm to the touch
    2. final display was 02
  3. Ran # 59 to test the motor and had 02 on the display (Harvest not completed)
  4. All other tests passed
  5. I did notice one day the emitter LED was projected but then the next day LED was not working.
    1. I replaced the emitter with a new one and the emitter was not working
  6. Occassionally, I would hear ice being harvested followed by the water fill but no further ice was made.
Question: Is there a way to test the emitter itself? I did place my camera against the emitter and see some flickering but I thought it was LED since I saw a red dot being sent to the receiver. I was hoping the new part would emit the LED that is visible.
Question: Is there a way to reset the ice maker other than shutting down the whole fridge?
Rick explains it here:
Your model uses the exact same receiver and emitter.
The Optics LED light will only be on for the first 5 minutes after power is cycled, machine unplugged and then plugged in. This is what Whirlpool says; If you have 14 VDC at the receiver, J1-1 to J1-3 and service test #15 is not reporting the correct status of the ice bin, replace both receiver and emitter:
I'm attaching your tech data sheet below so you can see TEST #15.
  • Tech Sheet - W10689354 - Rev A.pdf
