WSF26C2EXY02 Ice maker not working
george63
ny
WSF26C2EXY
I have a whirlpool WSF26C2EXY02 refrigerator/freezer,the ice maker stopped working any thoughts?
Here's the parts diagram for your model: Whirlpool Refrigerator WSF26C2EXY02 Repair Parts
Is there any water in the ice maker tray? Or any ice? Or is it bone dry?
If bone dry, look what Jeff mentions to look for here: FIXED: WSF26C2EXY02 Ice maker not getting water, found broken piece
If your water line connector is fine, then Run the machine in service diagnostics mode. Your tech sheet should be behind the lower grill on the right side or tapped to the bottom of the machine. Once you enter diagnostics mode use the test chart on the tech sheet to test the ice maker and fill valve.
Here's our main thread on this problem for your model: FIXED: WSF26C2EXY Ice maker not working
Ali Steere Grieco
Texas
Having the same problem -- providing water just fine, doesn't seem to be a leak (no water on floor near fridge) but it's not making ice. Ice maker is turned on and there is no blockage. Can you provide a link to the tech sheet? We cannot find one on our fridge anywhere to figure out how to enter diagnostics mode and run the tests.
Do you have the exact same model number WSF26C2EXY02?
The model number tag is located inside the refrigerator section on the upper walls or ceiling.
