WSF26C3EXW01 Whirlpool Refrigerator Side Too Cold
Chizdna
NY
WSF26C3EXW01
Hello, I'm trying to help my neighbor fix his fridge. The refrigerator side is set to the highest temp and still is at close to freezing. The air diffuser constantly opens and closes.
Is there a way to locate the problem through a diagnostic check on the control panel, or do I need to manually go through it?
Chris
Hi Chris,
Here's the tech. data sheet for your model: https://drive.google.com/open?id=1TE0iDnrfvcW81vrGgKL_g0jIbWBysMfq
You can get into the diagnostics and do those 7 tests steps and see if they pass or fail.
For the damper opening and closing, see if it does that opening and closing in step 3 if so then your damper itself is likely the culprit.
Here's the damper(diffuser) for your model:
W11177624 Diffuser
