WT5680HVA LG Top Load Washer High Pitched Squeal
wendtdc13
Wisconsin
WT5680HVA
LG
Hello,
I own an LG WT5680HVA top loader washing machine and just noticed this odd noise today. It makes a high pitch squealing noise and this only happens on low spin so mainly when it is barely spinning. If it’s spinning quickly, it doesn’t seem to make the noise. Any help is appreciated. I’ve attached a video to show the noise. I also removed the pulsator and confirmed the 10mm bolt underneath is tight.
Thanks so much for your help.
  • IMG_6098.MOV
That's the clutch making that noise. You'd to replace it or it will get worse. When you click the link to the clutch below you will see a video of how to replace it.
Here's the clutch assembly for your model you can order:
Clutch AEN73131403
wendtdc13
Wisconsin
Now when I ran it today, everything seemed normal and no noise whatsoever!
Is this absolutely necessary to replace or can I wait for it to worsen? Any issue with doing this?
You can wait for it to worsen, it won't damage anything else.
wendtdc13
Wisconsin
Jake, any idea if this would be covered under the Direct Drive Motor with 10-Year Limited Warranty that is included with the purchase of this washer?
Unfortunately not, this is your Direct Drive Motor:
wendtdc13
Wisconsin
Could that by chance be part of the noise?
The fortunate part, it still hasn't done this since I last posted this which is great.
Possibly, also check the rotor.
