FIXED WTA3510 Bosch Axxis Dryer is dead
chaulser
Wisconsin
WTA3510
Bosch
Dryer is about 8 years old and has always worked flawlessly. Then, two days it ago it's simply didn't turn on, no lights, nothing…just completely dead. I checked the breakers, there's power at the outlet and the 15 amp fuses are both good. Anybody have any ideas?
I haven't worked on any Bosch Dyers, but I did locate the service manual for your model, I'm attaching it below.
Hope this helps.
chaulser
Wisconsin
Thanks for the help! Based on research I've done up to this point, it's most likely the on/off switch itself or the control module. When I get that figured out, I'll update.
Butch
chaulser
Wisconsin
Ok, I get "0" resistance testing the control board at the pink plug/Heater E2, orange plug/Heater E3 or the yellow plug for drum motor/fan. However, at the little white plug/NTC R3 I get 30 ohms which is twice what the service manual calls for. What this means I'm not sure...other then if there's no resistance when there's supposed to be (calls for 25-29 ohms and I get zero/nothing) I assume this means the control module is no good. Right???
Do I even need to test the control module with the start/stop switch?
Butch
Yes Butch, I would agree with you.
Go ahead and order the control board, but first what's the last digits of your model number? UC/13 or UC/4?
chaulser
Wisconsin
Okay…replaced the supply board and everything seems to work fine. After I put it in I tested it with my ohm meter and it had the same readings as the old one. Go figure. Maybe I was doing something wrong. Well, at any rate the dryer is working just fine. Thanks a bunch for all your help Jake!
Butch
Excellent Butch, I'm glad to hear that your back in business.:)
