FIXED WTW4800XQ4 Washer will not spin
Redrail
Rockaway Park
WTW4800XQ4
This washer will not spin. Display stays on spin. No flashing. I have changed the actuator but still having same problem. There is a clicking sound but still not spinning.
Please recheck your model number again, nothing is pulling up for that one.
Here's the results I do get:
WTW4800BQ0
WTW4800BQ1
WTW4800XQ0
WTW4800XQ1
WTW4800XQ2
WTW4800XQ4
Can you pinpoint where that clicking sound is coming from? Down at the bottom where the motor is? Or at the top inside the console? If down at the bottom where your motor is, tilt the washer back, then turn your transmission pulley and see if it turns both ways freely.
Here's the tech. data sheet for your model: https://drive.google.com/open?id=1psVH4VJFVWLEFo_Kf8Dwp9OlD8vPDuVG
Get into the diagnostic and post the fault code or fault codes you get.
Page 2 of your tech. data sheet do: ACTIVATING THE SERVICE DIAGNOSTIC TEST MODES
Then do FAULT CODE DISPLAY MODE on Page 3
Then you can see what fault code/codes you are getting on Page 6 and Page 7: FAULT/ERROR CODES
ALSO: Take the belt off and remove the transmission pulley and remove the plastic cams and see if the teeth are worn down there, that can make it just keep clicking and not spin. If the teeth are worn down order and replace that Splutch cam kit.
Here's the sputch cam kit for your model:
W10721967 Splutch Cam Kit
Video included in part link.
Excellent Redrail, glad to hear the new Splutch kit fixed it.:)
Thanks for the update! I'm MARKING your thread as FIXED.:)
