WTW5000DW1 Whirlpool washer No light
Brokenwhirlpool
Texas
WTW5000DW1
Hi! My whirlpool washer, WTW5000DW1 has no lights when plugged in. I flipped the breaker, checked the outlet with a different appliance- it works. There is almost a draining type noise when it’s plugged in, but nothing actually happens and no lights come on at all. Please help! I need clean clothes- it’s football season!
Check the diagnostic LED on the main control board and see if it's on or off.
Remove the two screws behind the console on top. Use a putty knife under each end cap and release the two clips, one on each side. Fold the console forward to access the main control.
LED ON -- The Control is detecting correct incoming line voltage and the processor is functioning.
LED OFF – Control malfunction.
No the LED is on the back of the control board I posted the link to above.
Watch this video to access it:
See if it will go into service mode and check for error codes. Follow the steps on the tech sheet. I'll post a copy in case you don't have yours.
  • WTW5000DW1-techsheet-w10740624-revb.pdf
Brokenwhirlpool
Texas
Super helpful thank you. Is there a fuse on this model. I’ve read if it overheated during the water interruption it could blow the fuse
