- WTW5000DW1
- Whirlpool
- 1-5 years
Whirlpool Washer WTW5000DW1 recently stopped agitating. When it gets to that part of the wash cycle, you hear a continuous clicking sound and you can tell there's a heavy power draw. I have removed the wash plate and the splines are all intact. I also removed the center hub and those splines were also intact.
I cleaned everything out and ran it without the plate and hub to see if the transmission shaft was moving properly, and at that point everything sounded normal. So, I first replaced the center hub and ran it again. Once again, it held up at the agitation stage.
The reason this confuses me is to my knowledge, the center hub only connects the tub to the transmission shaft. And it does spin properly. But, once that center hub goes on, everything seems off again. Should I replace the center hub, even though the teeth are not worn and it seems okay? Thanks.
