WTW5000DW1 Will not go into Highspeed spin
snglittlerock
WTW5000DW1
Our Whirlpool WTW5000DW1 will not go into highspeed spin during regular cycles but will when running auto calibration. It will agitate just fine.
when it gets to the part of the cycle where it should spin in the high speed mode it makes 3 very distinctive loud thumps then doesn't spin. If you wait it will start to rinse again and repeat the noise.
This machine is about 4-5 years old.
Hi, Let's check for a error code.
Here's the tech. data sheet for WTW5000DW1: https://drive.google.com/open?id=13EInFAAf99HeIgo6JNhYxCuG3RSqZdZG
Page 2 of your tech. data sheet do: ACTIVATING THE SERVICE DIAGNOSTIC TEST MODES
Then do FAULT CODE DISPLAY MODE on Page 3
Then you can see what fault code/codes you are getting on Page 6 and Page 7: FAULT/ERROR CODES
snglittlerock
We did that and we get the lid switch code. The lid does lock at all points of cycle.
I doubt it's the lid switch, because, like you said, it wouldn't spin at all.:) Get into the FAULT CODE DISPLAY MODE again and try again.
See if this video helps you:
If the error code is F7E1 or F7E5 then its most likely the shift actuator.
Here's the shift actuator for your model:
W10913953 Actuator
Here's the video that shows how to replace it:
Also check your splutch cams to see if the plastic teeth have worn down, if so replace that too.
Here's the Splutch assembly:
W10721967 Splutch Cam Kit
Video included in part link.
Ok, watch this video and see if this is making the same noise yours is:
Its possibly the hub underneath the washplate, that's stripped.
Here's the hub for your model, its located underneath the washplate:
W10528947 Hub
To remove your washplate, Watch this video below, wiggle the washplate while pulling it up.
I'd first check your hub to see if the teeth are starting to grind down.
The hub has screws that hold it in place, you will see them once you remove the washplate.
Look at these photos below of the teeth grinded down to smooth.
snglittlerock
No that's not the same noise. Mine is lower in the machine and sounds like something trying to catch. Usually 4 times then stops. I am running it in normal cycle for a few more runs and checking the codes each time to see if one or more start dropping off. I didn't see a way to clear them other that that.
Can you please make a video of that noise and upload it here?
At any rate, check your hub, to see if the teeth are worn down to smooth.
snglittlerock
I'll check the hub but the machine agitates just fine and we still get the slow speed spin. I'll try and get the video tonight as well.
snglittlerock
Ok, you were right. When I watched the video of our own machine it sounded a lot like the one you posted so I won't bother posting ours. Funny how different it sounds on the videos vs in person. I have removed the hub and it is worn smooth. Ording part now and feel certain the next post will be it is fixed.
Thank you Jake.
Excellent, yup that new hub should fix it.:)
Yes, keep us posted.
