WTW7000DW1 Whirlpool CABRIO WASHER NOISE
spikey
deerfield beach
WTW7000DW1
the subject washer just starting making a bearing type noise on the final rinse/spin cycle. at no other time do i hear the noise during the wash cycle and this about 2 weeks ago and of course it's getting worse. any ideas and suggestions are appreciated. see attached video.
  • IMG_3646.MOV
    17.4 MB
If your noise in spin cycle sounds like a jet airplane, then you need W11393685 gearcase. The bearings are not available separately.
@dashriprok is correct about the jet airplane noise being the gearcase, but yours sounds more like a rattling noise in spin.
Unplug the washer and check your rotor bolt and rotor first. Make sure your rotor bolt didn't come loose.
Here's your rotor bolt: W10752189
This video shows you how to access it:
Also, check to make sure the rotor is not cracked.
Here's the rotor for your model:
Rotor W10754161
as usual you have more answers. thanks. i will check this out this weekend and get back to you. so to be clear, it's not a jet airplane type noise that is heard on the video? thank you
No, it sounds more like a rattling sound.
If the rotor bolt and rotor are fine, it could still be the bearings in the gearcase.
I haven't replaced the gearcase(transmission) on this model as of yet.
Here's the gearcase(transmission) for your model, if needed: Gearcase W11393685
There is a video AppliancePartsPros just posted that gives you more detail on how to do it:
