WTW7300XW0 Water issues with cabrio washer
Bkelley
Kansas City
WTW7300XW0
Currently getting error codes F30, f71 and f72 on a cabrio too load washer. When I run the diagnostics the water does not flow to the the detergent, bleach Or softener cups and then gets stuck in C8
I asked our tech BB if he has the tech. data sheet for your model.
What was the problem with the washer originally? No water coming in at all?
Thanks BB!
LF(F30) flashes when the water level does not change for a period of time OR water is present but control does not detect the water level changing.
➔ Is water supply connected and turned on?
➔ Are hose screens plugged?
➔ Is water siphoning out of the drain hose?
Check for proper drain hose installation.
➔ Is the pressure hose connection from the tub to the machine/motor control pinched, kinked, plugged, or leaking air?
➔ See TEST #2, page 4.
I replace a lot of water inlet valves for this long fill problem.
W10364988 Water Inlet Valve Assembly
Installation video is included in that part link.
