zechterling
- WTW7600
- Whirlpool
- 1-5 years
<b>Whirlpool Cabrio WTW7600XW2 </b>
The drain pump on my Cabrio washer will not stop running. When I run the automatic diagnostic test it gets stuck on step C8. I've got an overload error code on it, and I've blown out the pressure tube. I've also did a pressure transducer calibration. The inner drum is free, and the stator doesn't have any cracks in it. I read that those could cause an overload error code. One more side not is that when plugging the machine in I get a spark from the outlet. Prior to this problem happening there was problem with the machine acting weird, I believe it was not a tight fit inside the outlet. I've since replace the outlet with a brand new one. When I did replace the outlet the black wire insulation was burnt off about 3 inches back.
Any advise or direction would be greatly appriciated. Oh, and when I plug it in and hit start the drain pump turns on and won't shut off. When you try to hit another button you get the invalid choice beeps and the only way to stop it is to unplug the machine. It's as if it think there is still water in the machine and it wants to drain before it tries anything else.
