WTW7800XW2 cabrio error code UL always
Jakedude
Calif
WTW7800XW2
My cabrio starts to spin & then at the 9min mark it stops, showing U L code so I redistribute the load push start pause button & it resets to 13min starts to spin then at 9 it stops again UL code again everytime it never comes out of its issue. What is going on? Anyone experienced this issue before?
uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
➔ Display clears if mini-cycle successfully rebalanced the load.
➔ If the mini-cycle is unsuccessful, uL will flash until the lid is opened, allowing the customer to view and redistribute the load.
Does it do this on every load? Try with a empty load and see if you still get the UL code, if so you will need a new suspension spring kit.
Here's the Suspension Spring Kit for your model:
W10247710 Suspension Spring Kit
