WZF34X18DW01 Whirlpool Refrigerator compressor pipe freezing over. No ice on coils
Toner
South Carolina
WZF34X18DW01
Freezer had stopped freezing and was running around 45 degrees. Took all food out and took evaporator shield off to find the upper left corner was a complete block of ice. There was no ice on the evaporator. Let sit for a day and dried inside. Plugged it back in and the ice is already reforming after only 15 minutes. Just trying to figure out if this is worth repairing or if I need to get a new freezer. I have some skills with repair, but am by no means a DIY with electrical or cooling systems. Any help would be appreciated. Picture of current icing at 15 minutes attached.
That frost pattern is a sign of a refrigeration system problem. That might be lack of refrigerant or a problem with the compressor.
When not covered by a warranty either service being required is often not worth having repaired unless it is a special size or built-in, etc. and would be difficult to replace.
Happy shopping.
