YGEW9250PW1 Whirlpool Dryer PF Code
Chevy2
Edmonton
YGEW9250PW1
Hi, my dryer code shows PF. I’ve followed directions by:
> Door firmly closed
> press Control On
> press End of Cylcle Sognsl (louder)
> press Start
Still no go. Also ran Test#3a Thermistor Test but still no go. Could it be Thermal Fuse?
thanks
PF flashes to indicate that a power failure occurred while the dryer was running. Press Start to continue the cycle, or press Pause/Cancel to clear the display. If PF doesn't clear. the control is bad. It's been discontinued and is no longer available:
Chevy2
Edmonton
Hi Rick,
Thanks for your prompt response. You are right, PF continues to come on after several attempts to clear it as suggested.
David
Chevy2
Edmonton
Hey Rick, just curious ... if the control board was not discontinued and available, what would it cost? (approximately)
THANKS AGAIN
David
