YGY397LXUS04 Whirlpool Range Element Won't Cut Out
Youngjames
Newfoundland
YGY397LXUS04
Recently changed my baking element as it gave out. There was a white burned spot in it and it no longer heated up. I ordered the element and replaced it no problem. I used the stove that night and my food burned up in no time at all. Never thought nothing of it at the time, and assumed I lost track of time. However, it happened again tonight. Upon further inspection, the element comes on, and stays on. The oven beeps when it reaches the set temp, but element keeps going. Where do I start? Google tells me circuit board. Not fun, as the board is close on 500 bucks by the time it's delivered. Any way to diagnose it without buying a new one?
Also, I cannot find a repair manual anywhere for it. I have no idea how to get to the circuit board since my panel is on front of the range. Any help or guidance? Thanks!
Model: Whirlpool YGY397LXUS04
Circuit board model number?? WP8507P390
Why is it so expensive??!
Youngjames
Newfoundland
Afraid that would be the case. So I guess there's not much point starting anywhere else first (temp sensor, probe etc?) That part you sent will cost me 420cad by the time it's converted and shipped. Awful 😒. Ah well, what can you do
There is no harm in checking....but what you described sounds like something more like the control was damaged with the element let go.
1000-1100 ohms at room temp.
Oven temperature sensor kit
Youngjames
Newfoundland
Thanks for your help so far. Like you suspected, it appears to be the oven control module. I have it ordered and it'll be here tomorrow.
Any do's or don'ts so I don't ruin it by accident? I had the power off and took off the front plate and sure enough, easy to get at. Is it as simple as unplugging everything and swap out the boards? Is the module stuck to the front panel some how with the buttons on it?
Pull and push the wires, try not to remove them all at once and get confused. Takes pics if needed.
The key/touch panal? If yes, it is peel and stick/stuck on.
Oven touchpad switch membrane in black
Youngjames
Newfoundland
Ok, so upon further inspection, I won't have to worry about the key panel right? It appears to be just 2 screws holding the circuit board on and a bunch of wires. I don't have to worry about separating the sticky adhesive for this job do I?
Unless replacing it, no you should be able to just leave that alone.
