YWEE760H0DS0 Error Code F8E0 Cooling Fan Speed Too Low
vince_li
YWEE760H0DS0
I opened up the range, followed the service manual to measure the resistance of the fan motor with a reading of around 135 ohm, so according to the manual I should replace the fan. My service manual is W10665227A, and it says I should look for a reading of 25 ohm. But I found a service manual W10665227B, which says I should look for a reading of 105 ohm.
My question is did Whirlpool changed the 25 ohm fan to a 105 ohm fan, or the rev. A manual is wrong and the rev. B manual is correct?
Since my reading is 135 ohm, should I replace the fan, if so, will the new fan W11107275 works?
Thank you.
vince_li
Thanks for the reply.
It's located under the cooktop and inside the left side of the chassis
Here is a thread with the same error code, same brand but different model:
In post #3, Jeff shared a Rev B service manual (W10665227B), which on page 11 it says "Disconnect control board connector P5 and check the fan motor for 105Ω resistance between P5-1 and P6-3." But my service manual is Rev. A (W10665227A), which says "25Ω" instead of "105Ω".
Rev B service manual 105Ω ... Rev. A "25Ω"
.... my reading is 135 ohm,
This company ships to Canada:
Added Canadian shipping site
