YWET4024EW0 Whirlpool twin thin washer leaks at bottom centre
fsp101
Schreiber Ontario
YWET4024EW0
Our washer leaks at the bottom, close to the middle. It seems to leak during the spin cycles when the water drains. It doesn't leak much but is noticable when looking underneath.
You will need to pinpoint if its definitely coming from the middle underneath the tub, because the main tub seal may have gone back and started leaking.
Here's the main tub seal for your model:
Tub Seal W10814296
If so, then you will need a Spanner wrench TB123A (To remove the basket lock nut with a hammer)
